I would like to use the CCGX to monitor my LPG tank, which has a 0 to 90 ohm range from the sender. Is there a way to connect it to the tank sender adapter so that it will correctly display the tank level?
Is the sender attached to analog/digital input or require the Victron VE.Can Resistive Tank Sender Adapter? https://www.victronenergy.com/accessories/ve-can-resistive-tank-sender-adapter
10 People are following this question.
