What LAN cable do you recommend to recieve the best signals for the auto start function?
If this is to use a LAN cable for 'autostart', by which you mean using a GX relay outputs for signal to a generator, then depending on how far away the GX is to the generator, you probably shouldn't use very thin cored LAN cable for low voltage DC signal, without making sure any voltage drop would be minimal.
If this is for data comms then as Kevgermany said.
Here we'd only recommend Victron originals.
But any fully wired good quality one will work.
39 People are following this question.
