joseprieto avatar image
joseprieto asked
AC available at the socket wall passing by Multiplus
I have installed on my boat the Victron Multiplus 24/3000. The question is: when at the marina, shore power connected, multiplus remote control at “charger only” position, the AC power that’s available on the wall sockets is rectified or is coming straight from the shore power, or is rectified by the multiplus?
I explain: I have an Sailrite sewing machine with a device that works only with power that do no came from inverters (pure sine) like Multiplus.
The same question when at anchor using the 7kw generator connected to the AC Circuit via Multiplus.
Multiplus-II
prein avatar image
prein answered ·
Yes, in charger only mode the power is coming directly from shore,
But a multiplus mostly creates a better, less noisy 50hz signal then what is often found in a marina (or generator)
