bazil avatar image
bazil asked
Clarity Multiplus 12/1600/70-16 fan - what's it really doing?
I have placed my Multiplus 12/1600/70-16 inverter in a cold environment (0° C) with ample ventilation space. This morning, despite a relative meagre load (500 W) whilst inverting, the fan was on.
As I understand it, the operation of the fan is there to stop overheating and will start up when the und gets too warm, however given this morning's discovery I though it prudent to source a second opinion.
I would welcome any information regarding the fan and whether it might be prudent to disable it.
Best regards
fandisable fans
kevgermany avatar image
kevgermany answered ·
Don't disable. It may cause the unit to fail and will invalidate your warranty.
It's driven by internal temperature. 500W is a significant load, will generate heat.
But if you're concerned you'll need to get your dealer to check the unit.
Also orientation would affect the units internal heat.orienamtatiin is not mentioned in the post. So if horizontal 30% load is definitely high enough to warm up things. (Even vertical)
bazil avatar image bazil Alexandra ♦ commented ·
Many thanks for all the advice! The unit is laying flat on a smooth surface; I'll see if vertcal mounting is possible.
