is that a correct way of wiring the Battery protector? if not, would you pls explain?
Thank you!
Thank you!
That's not the proper way to parallel batteries, and whether the BatteryProtect would be appropriate there depends on what you'll have connected to the Distributor - if you have any charge sources or inverters connected to the Distributor, then no it won't work there.
For reference please see Victron's Wiring Unlimited book (for discussion on the 4 correct ways to parallel a battery bank) and the BatteryProtect user manual for discussion on the acceptable ways to use/wire a BatteryProtect.
41 People are following this question.
