nvs avatar image
nvs asked
2 x SmartBatteryProtect ont the VE.Bus BMS V2
Hello, can I put 2 disconnect loads on the same disconnect loads port available on the BMS V2 . My first SBP is on the orion converter 24/70 to 12v that will on/off the converter and not the loads, and the second SBP will be for my 24V loads that will disconnect the loads directly...
Thank you
Battery Protect
pwfarnell avatar image
pwfarnell answered ·
That should be fine, the ATD port on the BMS is rated to 1A and the Smart Battery Protects only consume a few mA each.
