hemmi avatar image
hemmi asked
New Cerbo GX with 3 Data USB and GX Touch
I heard that it will be released a new version of the Cerbo GX where all 3 USB are suitable for data transmission. If I use a Touch GX, can I connect the USB of the Touch GX to an external USB port 2.0 or 3.0 so that I have all 3 USB ports of the Cerbo GX available for data transmission? Does the communication between the Cerbo GX and the Touch GX work over the HDMI? I ask this because I want to avoid a USB hub.
Does someone know when the new version of the Cerbo GX will be available?
Thank you.
cerbo gx
ejrossouw avatar image ejrossouw commented ·
It is already available but best to check with your supplier.
luphi avatar image
luphi answered ·
You can have the Touch50/70 powered by an external USB power supply.
Marc Elvery avatar image
Marc Elvery answered ·
Information about the Cerbo MK2 is on the documentation portal
https://www.victronenergy.com/live/venus-os:start
