canalboater avatar image
connection problem Config 3
I have a Multiplus 24v 3000va 70amp running 1812146.Hex firmware and need to copy the current settings to file and cannot connect since updating.
When I try to connect I get the following :-
Finds Target
Retrieves supported functions
Reading Block 1
Error during communication
VEConfigure 3update
canalboater answered ·
My multi is the same age as the one in the post you recommended but I am using a MK2 U.S.B. Interface and the software finds the target but after that it retrieves supported functions, reading block 1 and then shows a error during communication.
1 comment Share
Not sure what else I can suggest. Check that your Mk2 cabling (both sides) are good, and similarly for their connectors. And when you say update, do you mean updated VEC3? If so do you have a copy of VEC3 prior to the update?
kai avatar image
kai answered ·
I had a peek at the Victron document on firmware versions and the 18 prefix doesn't even appear. How old is the unit?
edit: take a look at
https://community.victronenergy.com/questions/6056/veconfigure-3-does-not-detect-multiplus-24-3000-70.html
Share
