treejohnny avatar image
treejohnny asked
Venus W/BMV712 on USB not showing under remote console
So I have 2 solar chargers connected through the VEdirect ports and the BMV712 connect to Venus through the USB. I am able to see BMV712 as connected device and see info as widget in advanced but I am sure there is a way to see BMV712 info in overview like I did when connected through VEdirect?
Venus OS
treejohnny avatar image treejohnny commented ·
Maybe this will get a response in the VRM category?
Hi @treejohnny
The BMV should work through usb just the same as on ve.direct connection.
Did you do a reboot so the old connection is forgotten?
I didn't 'reboot' through software but I did power cycle it. The biggest letdown is that the battery info is not on the landing screen of VRM like it was before.
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ treejohnny commented ·
I found the problem, the battery monitor was selected with the old connection, and because a different connection leads to a 'new' device in the list, this 'new' device needed to be selected as 'battery monitor'
I took the liberty of changing the setting for you.
Thank You!!
I kept trying to find the setting in the portal without going into the ‘Remote Console’, duh.
