josh1e avatar image
josh1e asked
smart battery protect - remote + voltage sense?
Hi. I have just installed the smart battery protect (200A) and have it sensing battery voltage. I've used Bluetooth to configure the voltage shutoff and reconnect successfully. For my use case, I would like to use BOTH voltage sensing and the H remote on. Please can you confirm if this is possible (to use both at the same time?) or, does using one cancel the other? I've read conflicting advice while searching for information. thanks
Battery Protect
You can use both.
But it will act like an AND-gate, both signals (remote and the "ON-voltage") have to be ON for the output to be ON.
If one of the signals is OFF the output will be OFF.
josh1e avatar image
josh1e answered ·
fantastic, thank you
