UPDATE 2023-12-06: v3.13 was released officially per just now. See https://professional.victronenergy.com/news/detail/227/ for the official announcement.
Good day all,
A small interruption while testing all the new things: its time for a backport release again.
Change log (compared to v3.12)
- Generator integration bugfixes:
- ComAp: fix Runtime hours display which was off by a factor of 60. Thanks to Srdjan Savic.
- DSE: fix engine speed reporting
- DSE: fix 7xxx MKII support
- ESS:
- Increase limit of 32.7kW per phase limit to 138kW.
- Fix problem where the recently introduced setting "Self-consumption from Battery" to "only critical loads" did not work correctly if a Multi on L1 was compensating for loads on other phases.
- DVCC:
- Fix bug where DVCC user charge current limit is ignored in systems with a VE.Bus BMS. Bug was introduced in Venus OS v3.00.
- RV-C protocol
- Fix TANK_STATUS DGN not being sent out; this was broken per v3.00
- Fix transmission of DGNs related to the GX itself; this was broken per v3.00
- Fix External control state field in the CHARGER_STATE DGN
- Improve CHARGER_STATE in case the charger is disabled or mains is not present.
- Improve INVERTER_STATE in case the inverter is disabled or cannot invert due to low battery.
- All features required for Dynamic ESS. Note that Dynamic ESS remains in beta for now. Having the feature in an official Venus OS release is just to prepare for official release.
Instructions: Venus OS beta testing & how to join/install
In case you don't know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions: How to post an issue?
By posting an answer below. Do please keep all findings organised: one answer issue per issue. So first check the existing threads if your issue has already been seen. And if it does, add a comment saying "me too". And preferably some more details. And in case its not listed yet, add a new Answer.
Note that Answers and Comments are two different things on this portal.
Lastly, before posting issues, preferably first revert to the latest official release (v3.10), to double check if the issue you're seeing was present there as well. Regressions require a different treatment than other issues and bugs.
And include information about the results/differences in behaviour in your report.
Instructions: Node-RED, Kevinās GuiMods or other add-ons?
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
GuiMods and other 3rd party add-ons: donāt report your gui issues here. Do it elsewhere instead.
Changes made by us can cause a compatibility issue with the GuiMods; and these betas report pages are for official firmware only.
