Alex Pescaru avatar image
Alex Pescaru asked
Multi RS versioning and PID
From the picture above, I am wondering which are the differences between PMR482602000 and PMR482602020.
I have a feeling that the first one (PMR482602000) is the version with single 4kW MPPT and the later (PMR482602020) is the newer version with dual 3KW MPPTs, right?
Then which hardware/product ID is belonging to the first one and which to the later.
Am I right to assume that A443 is for the dual MPPT version?
Thank you!
Multi RS
nickdb avatar image
nickdb answered ·
Yip, you are correct.
It may also list the rev in device info on VRM, but you'd need a cerbo online.
Firmware updates won't apply the wrong base code. VC app will also have the right software loaded.
Alex Pescaru avatar image Alex Pescaru commented ·
Thank you for being so kind and have the patience to answer my rookie questions... :-)
Alexandra avatar image Alexandra ♦ Alex Pescaru commented ·
@Alex Pescaru
Most people won't even know. Updating with Victron Connect means they don't have to worry about what firmware is loading.
Keep on asking questions though.... Totally worth learning everything you can.
