guru77 avatar image
guru77 asked
EVCS - Limit grid power while charging
Hi!
I would like to limit the grid power to 20A (1 phase), as it is the limit of my contract.
I've already set up the MP Grid current limit to 16A, but this does not work.
Charging with more than 16A should be allowed, as far as solar/battery provides sufficient, but grid power should never go above 16A in sum.
As soon as some other equimpent asks for power, the EVCS should decrease charging power as fast as possible. (manual and scheduled mode)
Is there some other config I'm missing?
Thank you!
ev charging station
10 comments
what is the fw version used?
guru77 avatar image guru77 Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
v1.27/4.4
guru77 avatar image guru77 guru77 commented ·
Multiplus v507 (v508 available but not installed yet)
Lucian Popescu (Victron Energy Staff) avatar image Lucian Popescu (Victron Energy Staff) ♦♦ guru77 commented ·
can you give me a print screen of the settings/general EVCS webpage?
Overload protection is not enabled, please enable it and try again
Thank you, sorry - haven't see that :(
no problem, just confirm if that solved the issue
it works perfectly. Thank you !!
Great!
