taylor-wagenaar avatar image
taylor-wagenaar asked
Multiplus 2 not showing utility/grid usage
I have 3 x Multiplus 2 inverters set up in 3 phase configuation. System has been running perfectly until last night.
As of 3am this morning , the phase 2 master shows no watts or amp draw. It is see 246V on line and still outputs power on and off grid. I suspect the CT for the grid side in the inverter is faulty.
Anyone else with this issue?
Multiplus-IIfault
gazza avatar image
gazza answered ·
There is not really a lot that can go wrong in them (CT clamp) unless subjected to abusive current... in which case you would know about it due to molten plastic. Have you checked that the cable is not damaged and the connections are solid and secure?
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
