riker1 avatar image
riker1 asked
Smart Shunt Voltage Starter battery wrong
0-bmv-erroer-trend-1.jpgHi
when adding the starter battery the voltage was shown right
but than a little later, voltage dropped in shunt , but not in real, I checked with meter.
see trend data. any idea?
there is a drop in starter voltage without any reason
Actuall voltage of starter battery is still 25.2 but shunt showing 23.7
SmartShuntstarter battery
pwfarnell avatar image
pwfarnell answered ·
Check the connections especially any crimp you may have made and the terminal where the sense wire connects into the Smartshunt. Also check the fuse, sometimes these can be loose in the holder.
riker1 avatar image
riker1 answered ·
nothing changed, I did not touch it, and voltage jumped as shown in trend diagramm
riker1 avatar image
riker1 answered ·
I measured voltage on cable , and it is showing the correct voltage, but shunt not
kevgermany avatar image
kevgermany answered ·
Do you have a common earth/ground/negative between the starter battery and the house system?
riker1 avatar image riker1 commented ·
yes common ground
riker1 avatar image
riker1 answered ·
yes
I am very astonished as I did not touch anything and the starter battery voltage just doubled
Your shunt must still be under warranty. Please contact your dealer for warranty service.
warranty is over , 4 years old
