gharshaw avatar image
gharshaw asked
Non ESS - AC Loads reflect load from Grid not AC Loads downstream from Multiplus
With a grid meter upstream of Multiplus without ESS enabled , is it possible to have the AC Load widget only reflect the AC output load of the Multiplus? The scenario here is that I have a motorhome with the Air Conditioner running that is not behind the Multiplus.
Thanks
CCGX Color Controlgui mods
5 comments
gharshaw avatar image gharshaw commented ·
Loving the new GUi-V2 but same issue for me. AC Loads does not reflect the Multiplus AC Out when not in ESS mode
What type have you configured the grid meter as? It should be configured as a grid meter, not as AC load.
gharshaw avatar image gharshaw nickdb ♦♦ commented ·
The grid meter is configured as grid
@mvader (Victron Energy) @Guy Stewart (Victron Community Manager)
May I get your thoughts on this issue for me. In my research I see that AC Loads widget is based on system consumption. Since I Prefer AC Loads to be about the AC output of the Multiplus, would this change be a DIY GUI modification change?
I appreciate any input you might have.
Thanks
gharshaw avatar image gharshaw gharshaw commented ·
@Matthias Lange - DE
Would you be able to give some insight on my question about the AC Loads widget?
Regards
CCGX Product Manual
CCGX Product page
