Michelle Konzack avatar image
Michelle Konzack asked
SOPzS Batteries and SOC mismatch
Good day,
I am Off-the-Grid (24V) and have only a simple System running which work perfect, except for the SOC.
I use 4 battery sets of each 735Ah at a C100 and use 4 BMV702 plus 4 BatteryBalancer.
Currently I charge my Batteries (I sucked 1680Ah out of 2940) from a Generator but one thing pzzzle me since quiet a while.
If i have a nominal C100 capacity of 2940Ah, i can get only 2352Ah (80%) out at 20°C, hence in the summer it is perfect.
Now in the Winter I get only 60%, hence 1764Ah, out, and then my batteries are at 22,2V.
However, the SOC state, that I have still 45% left.
Do my four BMV702 work correctly or do I miss a setting?
I have this question, because the Grid Provuder Elektrilevi has installed a 75kVA Transformator near by and it is standing on our ground, hence I can dig a 200m trench myself, but an AXPK 4G25 in the ground with a connection box at the end and have only to pay 1500€ for connecting (plus my cable and digging) it instead of 36000€ letting them doing it.
And I can connect to the Grid to feed-in.
Also in Spring I will get my new batteries with 7329Ah (8 sets) with in toral 175kWh.
So, how do I then config (Dynamic) ESS for this odd SOC?
Note: On Tuesday 2923-11-21 we had energy prices whic i have not seen in the last 6 years in Estonia:
06 - 07: 21.722
07 - 08: 66.004
08 - 09: 58.559
09 - 10: 65.995
10 - 11: 47.75
11 - 12: 48.218
12 - 13: 58.556
13 - 14: 48.01
14 - 15: 39.598
15 - 16: 58.553
16 - 17: 93.262
7 - 18: 41.461
18 - 19: 24.002
Hence with my singel MultiPlus-II 24/5000 i could have feed-in 13h 3,8kW or 49kWh and earned 25,5€.
However, I plan to install three Fronius Symo 10-3 ACin coupled and a 3,5kW Windmill ACout cozpled (should deliver in my location at kwast 16MWh a year) in addition to my existing 1,86+4,10+5,5kWp Solarpanels and 5 windmills with 7,4kW in total.
Currently I have a trailer with 2175Ah of batteries with a Quatro 48/15000 here which emulate the Grid, but i can not get my system correctly wirking because of the SOC, the training videos on victron-professional did not help me with this problem.
Thankyou for your help and tips
SOClead-acid
pwfarnell avatar image
pwfarnell answered ·
Answer corrected in the comment below
The BMV only uses a single value of battery capacity, it does not include a calculation of SOC at different temperature even if the BMV702 has a temperature sensor for charge voltage compensation.
the only thing that I can suggest is that you manually update the battery capacity setting during the year as the temperature varies, maybe 4 times a year so that you are always close to the actual temperature and any errors are small.
pwfarnell avatar image pwfarnell commented ·
@Michelle Konzack I have to retract my answer above, I have just been reading the BMV-702 manual and Section 7.6.8 states that if you have a temperature sensor connected to the BMV-702 you can set a capacity compensation factor that reduces the effective capacity at lower temperatures. A not very common feature.
If you have a temperature sensor then look at this, otherwise you will have to adjust manually as noted above.
michelg avatar image
michelg answered ·
Hi Michelle,
Usually, the capacity is based on C20 / C10. I also use OPsZ batteries, and had to change the Peukert factor to 1.14, charge efficiency factor to 80, and battery capacity at 1250Ah at C20, tail current 4,00%, charged detection time 45m, charged voltage 29,7V ( I am on a 24V system). Discharge floor 50%. Current threshold 0,20A
The Peukert was difficult to find as you can see different numbers on Internet, but for my setup, this one is the most accurate I could find.
Michel
4 comments
You can calculate the Peukert for your battery.
You only need two of the C-ratings of your battery (printed on the battery or in the manual)
How to do the calculation is described in the BMV/SmartShunt manual.
https://www.victronenergy.com/media/pg/BMV-700/en/battery-capacity-and-peukert-exponent.html
Or you find a Peukert-calculator in the web.
Michelle Konzack avatar image Michelle Konzack Matthias Lange - DE ♦ commented ·
Thankyou @Matthias Lange - DE
I did not know this document.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Michelle Konzack commented ·
Reading the manual sometimes helps :-)
Michelle Konzack avatar image Michelle Konzack commented ·
Thankyou, I will try the same settings
