Martin Opdebeeck avatar image
Martin Opdebeeck asked
Charging Without using Batteries
I would like to not use my batteries for charging the EV.
I can of course manually set the batteries on keep charged, but I also do not want to charge them if not at 100% during EV charging . Is this possible in VRM or Venus ?
hereby you see Pylontech batteries dropping during night scheduled EV charging process
I would like to avoid unnecessary cycles on the 21 kw Pylontech Bank
evcs
crisg avatar image
crisg answered ·
Yes it's possible using NodeRed. You musst programming this yourself.
crisg avatar image
crisg answered ·
Like this
crisg avatar image crisg commented ·
In the case described above, the battery inverter is simply deactivated if a charge is detected on the car battery between 10pm and 6am. as soon as the charge stops, the inverter is activated again.
Martin Opdebeeck avatar image Martin Opdebeeck crisg commented ·
Great job ! thanks a lot.
It is a bit too early for me to use Nodered but I will certainly do.
But I think this should be a nice satndard feature in standard tools.
Et je vois que tu charge la tesla de nuuit ;-)
