I have problem uploading firmware to EVCS. I am trying to use firmware file "EVCS_Main_FW_OTA_V01.25_C025.evcsup" but it always fails.
I tried to reset to factory, nothing helped. current version 3.3/1.22
What else should I try?
Is the system online and added to the VRM Portal?
If yes, try the update using the VRM Portal.
Tomas
There is a button "Firmware Update" (you might need to activate two-way communication in the settings of the GX device)
https://www.victronenergy.com/live/vrm_portal:remote-firmware-update
Thanks for Your information. I activated two way communication and now Firmware Update button was available. Unfortunatelly the result is the same:
Can you tell me the VRM portal ID? I can try from my side. Make sure the Wi-Fi signal is strong enough. If the communication is unstable, that will be the outcome.
EVCS was updated few hours ago, please check it.
Lucian
Hi @Lucian Popescu (Victron Energy Staff) ,
thanks, You sucesfully update it to version 1.26-beta-2/4.3, I had connected to my WiFi and set it up. Unfortunatelly Cerbo sees EV charges double names.. I have two chargers, one ends with IP 192.168.15.202 (EVCS-VRATA), and second one IP 192.168.15.203 (EVCS-ROZVADEC). But in Cerbo (192.168.15.201) is only name EVCS-ROZVADEC but twice..
I had probably interrupted Your work, so I am sorry for that..
-tz
Reboot solved this. Thank You very much, You solved my problem.
Thanks.
Tomas Zavodny
Hello, I have the same problem with EV Charger:
An error occurred during the update process. Please try again later!
Error Message: device-update: Connection error Error: 733
I tried update it through VRM and web page too. Restarted Cerbo but got same error. My VRM portal ID 48e7da887a07.
Can you please look at it?
Hello @Lucian Popescu (Victron Energy Staff)
I am having a similar issue although not code 5.18.
This unit has firmware v1.22. When attempting update to 1.28 via browser and direct WiFi connection, the update fails at around 6 to 8% progress. When trying to update via VRM we get message Error 733 Connection Error and another box 1512 You dont have sufficient rights to perform this action. I have tried many times.
Can you please take a look? VRM 780473a9bcbb
Thank you, Owen.
Hi, it tried but the connection between GX and EVCS is very unstable, probably that's why firmware update is not working.
Below picture with a ping test between GX and EVCS, 60% loss
If you manage to improve the connection, and it is still not working, contact me.
Hi @Lucian Popescu (Victron Energy Staff). We have temporarily improved the WiFi connection and we still get the errors in the below image when trying to update firmware. We also cannot perform the update via laptop immediately in front of the charger. Any suggestions please?
36 People are following this question.
