felix-gast avatar image
felix-gast asked
EVCS Software Bug after update to 1.25
I have problems to connect the EVCS to my network. After i updated the firmware from 1.22 to 1.25 the wallbox will continue restart and i can see the wifi but if i click connect an type in the wifi password everything looks normal but the EVCS will not connect to this i can just use it as standalone without connecting it with my cerbo or at least to connect to the wifi.
I tried to reset to factory settings but without any changes.
Even if i want to change any other settings e. g. Charging current after i press "save" it doenst take the changes.
It seems to be an software bug for me.
But with the old software I couldn't also connect to my cerbo 100%. I could see the cerbo device after I connect to the wifi and also see the battery state on the evcs but in the VRM or on the color control I could not see the EVCS. Maybe the evcs Is not working properly.
evcs
