Hello, I'm currently living off-grid and using a Phoenix 48/1200 inverter. I'm looking to expand my system. Can I purchase another Phoenix 48/1200 inverter and connect it using AC coupling?
What do you mean with AC coupling?
Running both parallel?
No this does not work.
However, the Phoenix Inverter 48/1200 is a discontinued model and I suggest you to upgrade to a 48/3000 model or even a MultiPlus which is also a charger.
AC-coupling and the Factor 1.0 rule
39 People are following this question.
