Can I use the Easy Solar II GX for single phase 120V and 60 Hz AC In and AC out? The spec sheet indicates Inverter output 230 VAC 50 HZ. Charger input indicates 178-265VAC 54-65 HZ
No. The inverter will reject the 120v incoming.
And won't output inverting anything less than 230v.
You will need to find one that is designed for 120v.
You could couple it with an Autotransformer that could output 120V or 120/240V split phase, but you would have to feed it with 240V.
56 People are following this question.
