bm6 avatar image
bm6 asked
Parallel Connection with Phoenix Inverter
I have a Phoenix Inverter 48 | 5000 | 230V (older version) with two RJ48 sockets Ve Bus No Ve direct port i am charging the batterie with a Bluesolar 150-70 and would like to run it in a Parallel Connection with the EasySolar-II GX 48/5000/70-50 is this possible ?
if so could the GX built in to the easy solar also display the Phoenix Inverter 48 | 5000 | 230V pluged in via the Ve Bus and the Bluesolar 150-70 connected via the Ve Direct?
EasySolar All-in-One
