carlosleon avatar image
carlosleon asked
Help choosing the right MPPT
150 W SOLAR PANELS INSTALLATION INVERSOR Victron.pdf
I am from Spain, I've recently bought a RV and I am trying to install solar panels,
I have so far connected 4 Flexible 12V 150W panels making array number 1, and array number 2 its 3 panels 12V 150W in series and then connected to 3 - 50W panels connected in parallel themself , so in other words I have two sets both equally given VOC: 93,6V VMP: 79,2V AMP: 7,58A ISC: 8,03A
I have a DC combination Breaker Box 2 in 1 (so both arrays are connected in parralel given a maximum possible output of 1200W VOC: 93,6 VMP:79,2 AMP: 15,16 ISC: 16,06A.
from there it should go to the MPPT (WHICH ONE SHOULD I CHOOSE?) connected to a Victron Inverter 48/5000/70A . I need to charge a 48V 7 KW Lithium battery
Can anyone help me deciding which is the correct Victron MPPT for my Solar instalation?
Thank you very much from sunny Spain
MPPT ControllersMPPT SmartSolarmppt calculator
nickdb avatar image
nickdb answered ·
panpower avatar image
panpower answered ·
If the peak voltage can’t go over 100v you can use the 100/20 48v smartsolar. If you want to be sure 150/35 ...and for a future update
carlosleon answered ·
Thank you for your answer,
I have a Victron 48V/5000/70A inverter charger, should I have an MPPT with a least 70A to match the Inverter charger output?
panpower answered ·
70A x50v is about 3500w of solar. You don’t need a 70A mppt because of the inverter.
If you have space for 3.5kw of panel you can choose a bigger mppt.
