s1277 avatar image
s1277 asked
Using Temp Sensor non Battery Question
Using the ASS000001000 Temp. Sensor for Quattro, MulitPlus & GX Device with my cerbo monitoring temp of my HW compartment, black water tank compartment, under my sink and main cabin.
Can I just have the remote end exposed to air or does it need to be attached to something metal or plastic to get correct data ?
I have VRM and Cerbo set to F do I still need to set temp sensors with an offset? seems to always be in the 50 f range
how far can I extend the sensor?
On Cerbo does red face out and black in markings are unclear?
How do I get sensors to show temps in the tanks column on the Mobile Overview page
Temperature Sensor
chrichri avatar image
chrichri answered ·
The metallic end does not need any contact.
50F seems ok. =10°C
Temp in Tank view is not implemented.
In VRM Portal view you will see it on right side.
I would not too much extend. Use the ruuvi sensor for humidity and temp if you would like to be cable free.
s1277 avatar image s1277 commented ·
I do not think they are accurate or need an offset in my rv no heat and show really warm
compared to my bluetooth devices I m replacing
pwfarnell avatar image pwfarnell s1277 commented ·
Effect of sun shining on the RV warming it up a bit more than the air temperature.
s1277 avatar image s1277 pwfarnell commented ·
all but one settled One seems to be high have to move it see if its by something warmer The other sensors are next to these so should be close to same temp
Victron temperature sensor disambiguation table - which product supports which sensor
