wlwest avatar image
wlwest asked
Can the Blue Smart IP65 15A charger charge my 200ah LifePO4 battery
I purchased 4 200ah LifePO4 batteries. My plan is to top them each off individually prior to hooking up in parallel to my Victron 3000 Inverter/Charger. Will the IP65 15A work even though it is rated up to 150ah? I was thinking it may take a little longer but still top the battery off. Once each are topped off then the 3000 will keep them charged. What do you think?
ip65
Nev avatar image
Nev answered ·
It will charge your batteries just fine either individually or paralleled.
Ensure that it is set to a suitable LiFePO4 charging profile.
Our motorhome has 2x 4 cell 300Ah LiFePO4 batteries in parallel.
Although rarely used the Victron IP22 30A charger is set to charge at 15A and easily tops them up overnight (4pm - 8am) if the sun has not shone all day.
Our typical daily draw is 120-150Ah.
Mike Dorsett avatar image
Mike Dorsett answered ·
If all the batteries are to be connected in parallel (4P) then you would not need to 'top them off' provided the rest voltage of each is the same +/-50mV. If connecting in 2S2P (24V) then charging to 80% say 3.4V per cell, would ensure that all are at very similar SOC.
