wiringocd avatar image
wiringocd asked
MPPT 450/100 False BMS error 67
Getting false reports and causing complete shut down on inverter side of system it will repeat this error in a loop about every 15-30 mins.
Victron 48v/5000 inverter
18 270w panels
victron 450/100 MPPT
Lithionics 51v 630ah battery bank
Lithionics is tied to the Cerbo via VE CAN. VE Can network setup as RV-C
This issue has happened ever since doing the 1.11 firmware on the 450/100. Is there any way to revert the firmware back to 1.10 or 1.08. I looked on the victron page to find the older firmwares but do not see any previous firmwares listed for the solar controllers.
MPPT ControllersBMS
Alexandra avatar image
Alexandra answered ·
@wiringOCD
See attached.
Although if the whole system is shutting down I would wonder how often the BMS is sending a signal? The GX will give that error usually after quite a few minutes of no contact.
MPPT_RS_450-100A_A110_v01.10_044858.zip
