can I put 2 MPPT's on same lynx distribution port assumes fuse is good
I do not have room for second lynx distribution in line
is there another solution if you cannot do this like cable the 2 distributions together or add a fuse block etc
It will work. Or connect to the red and black connectors at the end.
40 People are following this question.
