big-ste avatar image
big-ste asked
Cable for smart bms cl 12/100 to multiplus 12/2000 VA
Hi, I’ve install the cable from the smart bms cl 12/100 to the multiplus 12/2000va into the remote on/off (red top, black bottom) the multiplus will not switch on! However once I disconnect and replace factory black u wire in remote switch all is working. I’m sure I’m missing something simple, but can anyone advise please?
Multiplus-II
Mike Dorsett avatar image
Mike Dorsett answered ·
The remote on the BMS is not designed to be connected to the remote on the Multi...
Remote on/off terminal
• The Remote on/off terminal can be used to disable alternator charging while the BMS functionality will remain active regardless
of the remote on/off state.
You need to install the 2 wire BMS assistant and to wire up the load and charge enable connections per the manual
https://www.victronenergy.com/battery-management-systems/smart-bms-current-limiter#manuals
big-ste answered ·
Thanks Mike, do I use the alarm contact and if so which of the 3 contacts? Cheers.img-0329.jpeg
