Can someone explain what is this notification about?
Cannot clear it.
Where in "Device list" I can find "Inverter/charger entry" and what should be done with it?
Cannot clear it.
There will be a mk3 update option on the GX console under the inverter entry, scroll down. It's not on VRM.
Thank you for pointing me to the correct "Device list" :)
When I got there I was faced with this information:
What this NOTE is telling me?
Will I be faced with a temporary blackout?
Is the power supply to the cerbo gx interrupted when restarting?
Hi, not if you power the Cerbo from the battery.
But in the (unlikely) chance that in your system the Cerbo is powered using a AC/DC power adapter on the output of the inverter, then yes.
In general: that update is usually harmless, and in some cases it triggers an inverter restart, very short (seconds) outage of AC power.
Its due to a bug: once updated this time, we don’t expect that to happen again in future updates.
Ps. See also Cerbo GX manual, it has an entry for this error code.
Would this update cause any settings changes to the inverter? I'm having this message, but will not be on-site for months.
The one to avoid is the multiplus operating system. It can be done, but it's more involved and usually not needed
I've updated over 20 sites, non of them have had problems, but the notice is there for a reason. I would advise to contact the client while update.
43 People are following this question.
