Can a Quattro backfeed AC current into the DC side of the system? As in the Quattro send AC current into a Victron 150/70 MPPT charge controller which then would end up at the PV array?
Hi @AHTrimble,
The toroidal transformer in the Quattro provides galvanic isolation between AC and DC.
39 People are following this question.
Victron Multiplus Ground Issue?
Can a GX access information if 2 Multiplus are on the same bus, but driving two separate AC loads
N/####/system/0/Connected Not accurate / changing & N/####/system/0/Ac/Alarms/GridLost
measuring separate AC power usage from inverter via VRM
Can setting low temp cutoff in BMV-712 stop AC converter charging?
