philip-nedergaard avatar image
philip-nedergaard asked
Multi compact AC IN problem 12/2000/80
Hi All.
I have a boat that cannot charge from shorepower.
It will go on trying to sync, but when I hear the relay it will switch off. Only the amp in (set to 7A) will continue.
I will list the things that have been checked. And screenshot for software
screenshots.pdf
AC IN 235V 50HZ
DC out 13,1V (Lithium)
Inverter is working
Have tried to swap batteries to an AGM but still does not work.
Have tried to turn on "weak ac input"
tried the dipswitches with and without panel mode
turning down AC on the digital control
turning down the charged amps
Everything looks ok
Conditional AC input has also been checked.
Now what I ahve found is in VEconfig. The AC in V and Hz numbers are orange and then red.
Which should mean that the AC in has been rejected. But the multi et set to standard setting.
low disconnect 180V
High connect 265V
low connect 187V
high disconnect 270V
Accept wide input 45-65Hz
And the input is 235V 50,1Hz
So it should be fine. What could then case it to reject the AC in? Quality of the sine or???
I am stuck now because everything seems fine but the combi is upset.
I hope someone has tried this before. I have never seen this.
screenshots.pdf (12.9 MiB)
