The remote H & L pins are not labeled on this new smart battery protect. Please help me determine which is which. Thanks
Apologies for the confusion. We will document the remote on/off pin orientation and function more clearly and adjust the labelling on the BatteryProtect.
The pin labelled as REMOTE is the H pin and can be either shorted to the other pin or connected to the battery.
The second non-labelled pin has no other function.
In this respect, the BatteryProtect does not have the same L/H pin configuration and function as a Smart BatteryProtect.
Please note that your device is not the Smart BatteryProtect, but the BatteryProtect and therefore does not have Bluetooth functionality.
The manual depicts a different orientation of all PINs on the smart battery disconnect.
44 People are following this question.
