nero avatar image
nero asked
the system draws energy from the grid as a priority
I am solving a problem with ESS.
I tested the ESS 3 mode, when I controlled the system externally via Modbus TCP, I controlled the dynamic ESS with register 37, where I cyclically (every second) wrote the value 0 (power from the network).
Everything worked great.
When I wanted to return the system to ESS mode (without battery life support), the system preferentially draws energy from the network, not from the battery (charged to 100%). As if the internal ESS cycle of mains power management could not be started.
In register 102, the value is 0 (the system preferentially draws power from the network).
When I want to write the value 1 to register 102, it doesn't work.
Where did I go wrong that ESS is not working?
Is there any way to reset the registry settings to their default state?
It's possible that I overwrote registry values that I shouldn't have...
well thank you
ess settings
