bruce-thomas avatar image
bruce-thomas asked
Charging Station NS, Charging Cable?
Can someone help me locate a compatible charging cable? We have a J1772 vehicle and will be using 7.3kW in single-phase mode. There are no cables in stock here in the US with our vendor. Looked on Amazon but could not find anything that looked correct.
Thanks!
ev charging station
The charging station has the European Typ 2 connector, you will need an adapter for that.
bruce-thomas avatar image bruce-thomas commented ·
Matthias, thank you for the response. That explains why there are no cables in stock here in the US. I bought a Victron charger because their products work so well on our boat I wanted to stay with Victron. I am new to the to the EV world. We bought a Jeep Wrangler 4XE. It has a J1772 connector.
If I understand this correctly I need an adapter that is Male IEC 62196-2 to plug into the charger and female J1772 for the cable?
Than I would need a J1772 extension cable that is Male J1772 on the adapter end and then a standard car connector on the female end?
I have the charger and take delivery of the vehicle end of the week. Thanks for the help!
