As the title says really. I would like to connect 2x USB devices/connections. As you are aware EasySolar has only one USB slot. Will connecting a USB hub with an additional 4 ports would work?
I have the Digitus DA-70216 USB hub working with my easySolar II and it is working perfectly, no external power, I have a ve direct to usb connected to it, the em24 and bluetooth adapter and all are working ok.
Hi @P. Rogalski
I believe so, if you're in doubt maybe get a powered USB hub just in case.
(This works on raspi running venus os so I dont see why it would be different on a built in GX device).
Got one on order. Will feedback when it's all connected. Thank you
54 People are following this question.
