Fideri avatar image
Fideri asked
Hardware revision of inverters?
Hi Everyone,
This has been asked many times but no answer has been forthcoming. Example here: https://community.victronenergy.com/questions/189784/imbalance-when-running-two-multiplus-iis-in-parall.html
Basically, I want to parallel two Quattro's with a potential of adding more later. My fear is having an all too common imbalance which brings inefficiency to the system. Victron's "solution" of informing the vendor beforehand to get closely matched hardware is not an option as the Victron vendors here are fake (they take the money and run) and I didn't have the money to buy many inverters at once.
So, is there a way to tell the hardware revision number of a Victron inverter/charger? Apparently, some have a label with a hardware revision number but not all.
Fideri
quattro 10kva
nickdb avatar image
nickdb answered ·
Inverters have a serial number with the manufacture date. They aren't marked as rev1, 2, 3 etc like you see on mppts. It's best to keep the manufacture dates as close together as possible, typically sub-2-years.
Fideri avatar image Fideri commented ·
That's more practical, thank you.
