paskee avatar image
paskee asked
Battery isolator between batteries and chargers (MPPTs, Phoenix, Orion)
Hello Community!
I am reffiting my boat with LiFePo4 batteries.
For my purpose, I need to add a battery isolator between the batteries and the chargers: 2 MPPTs, a Phoenix IP43 and a DC-DC Orion.
Would this design work since the chargers won't be connected directly to the batteries?
I also plan to add a BMV712. Can the voltage and current information be sent to those 3 chargers in any way?
Thanks for your insights and Regards
P.
MPPT SmartSolarorion dc-dcPhoenix Smart Charger ip43isolators
kevgermany avatar image
kevgermany answered ·
Yes, but.
Depends on what you get.
To control the chargers you need a GX device.
With most (maybe all) supported batteries, the 712 is redundant as they'll provide the same info as the 712 to the GX device.
GX device needs either phone/Bluetooth for configuration or a screen. Screen is built in to some GX devices.
paskee avatar image
paskee answered ·
Hello and thanks for your input.
MPPTs are Ve.direct and can be talked to from the BMV712 if I am not mistaken. Not too sure about the Phoenix since its ve.direct port is described as "maintenance" only?
As far as I know the Orion is "dumb" and wouldn't talk to any ve.direct/bus/can or smart for voltage or current information. How would the Gx help there?
Victron DC to DC Converters Product Range
__________
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
