springboktwo avatar image
springboktwo asked
Charging 12v and 24v simultaneously from one mppt controller
Good day legends, hope someone could answer/help me in the right direction.
Equipment - Camper trailer with 2x 200w solar panels, 1 x 200a/h lithium battery and a Victron 75/15 MPPT controller.
I’ve added 4 x 24v electric actuators to open and close the two side doors, connected to 2 x 7a/h 12v batteries in series.
Question - Can I add the 24v battery pack (2x12v in series) to the same mppt controller that currently charges the 200ah lithium battery or must I add a second controller ?
Thanks in advance for your advice.
Deon.
victron community
kevgermany avatar image
kevgermany answered ·
Assuming the lithium is 12V.
The MPPT will not charge different voltages at the same time. Effectively you're trying to connect a 12V battery to a 24V battery. Won't end well
Use an Orion 12/24 DC:DC charger to charge the 24V pack from the 12V. But pick a small one. The 24V batteries are very small. Might be better to ditch the 24V batteries and simply fit an Orion 12/24 power supply, or use the charger in power supply mode.
