giampaolo avatar image
giampaolo asked
Are this Mega Fuses from Victron Energy
Good evening I bought some mega fuses on an online shop were Victron equipments are sold. The picture on the website showed this:
I instead received this:
On the plastic bag containing the megafuses there is a victron sn but on the fuses there i nothing written and they looks exactly the same of some chinese mega fuses that I bought on Aliexpress for 50 cents.
Is there someone maybe from Victron that can tell me if I may consider them genuine.
lynx distributor
If you ordered fuses for up to 32V you got the correct fuses.
Only the 200V 58V are blue with "window".
6 comments
giampaolo avatar image giampaolo commented ·
Thanks Mathias . Actually I ordered those in the picture rated 58 Volt 200 Amp. Those I received shows only the current but not the voltage . We will see if someone has more information on this.
Justin Cook avatar image Justin Cook ♦♦ giampaolo commented ·
The voltage of the fuses you received is listed on the packet - they are good for 32vDC maximum (so use on up to a 24v nominal system). If you intended to order (or did order) the 58v rated fuses, contact your supplier and arrange a return.
giampaolo avatar image giampaolo Justin Cook ♦♦ commented ·
Thanks Justin that's what I did.
2 Likes 2 ·
klim8skeptic avatar image klim8skeptic ♦ giampaolo commented ·
Nobody mentioned that 1 of the fuses clearly shows a 300A rating?
giampaolo avatar image giampaolo klim8skeptic ♦ commented ·
Yes that is correct .I ordered 4 200 Amp megafuses and 1 300 Amp megafuse . They were delivered all togheter in the same box.
Thanks for your answer Justin.
