wudwork avatar image
wudwork asked
SeeLevel SOUL in Cerbo, modify tank names ?
I just installed the SOUL. I found the Victron documentation indicating you only need (3) wires; turns out you MUST put the 120ohm resistor on the SOUL end as well as blue RJ45 into Cerbo. I found the cable I made for N2k version of Seelevel uses the exact same cable as SOUL. Best to follow instructions on N2k cable. All my sensors (2) gray, (1) white, (1) black all show on Cerbo. I tried to modify the tank names in Cerbo, no luck finding option. I tried @Kevin Windrem VeCan tool, could not find any option there either. Right now in GUIMODS, I set the "shorten tank name" to ON and now both gray tanks say "GRAY". I want one to say Galley and other to say Shower.
Issue 2: When I try to change tank capacity in Cerbo (from zero) it won't let me yet it still says 17% which is likely the right value.
Cerbo updated to FW 3.10
Any ideas ?
cerbo gx
