sjoch avatar image
sjoch asked
System variables - How are they calculated?
Is the System Voltage variable calculated in VRM or in Globallink?
Same question for System Current.
Is this a bug or correct reading?
In my case i have two smartshunts in two separate battery systems.
These two show up in VRM, But the system Voltage keep switching between the smartshunt values?
At first i thought that it got mixed in the ve network so i separated them into two different network groups so the mppt could sync the charging based on correct battery voltage in each system. I believe that is correct now But the system Voltage and Current still acts like this.
SmartShuntwidget vrmvrm bug
