tinkernut avatar image
tinkernut asked
How to validate ve.direct to USB cable?
Greetings,
I'm trying to connect an official ve.direct to USB cable to a RPi3 (also tried with a 4) and a SmartShunt. (Ultimately, trying to build a Venus OS Pi)
I'm trying with just the USB side connected to the Pi to rule out any ground loops
root@raspberrypi2:~# dmesg |grep tty
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootwait
[ 2.402322] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.510771] printk: console [ttyAMA0] enabled
[ 3.583704] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
no ttyUSBxx
re-plug of USB cable
[ 102.824643] usb 1-1.5: new full-speed USB device number 8 using dwc_otg
[ 102.924690] usb 1-1.5: device descriptor read/64, error -32
[ 103.144794] usb 1-1.5: device descriptor read/64, error -32
[ 103.364911] usb 1-1.5: new full-speed USB device number 9 using dwc_otg
[ 103.464954] usb 1-1.5: device descriptor read/64, error -32
[ 103.685086] usb 1-1.5: device descriptor read/64, error -32
[ 103.805353] usb 1-1-port5: attempt power cycle
[ 104.465463] usb 1-1.5: new full-speed USB device number 10 using dwc_otg
[ 104.905730] usb 1-1.5: device not accepting address 10, error -32
[ 105.005738] usb 1-1.5: new full-speed USB device number 11 using dwc_otg
[ 105.445953] usb 1-1.5: device not accepting address 11, error -32
[ 105.452229] usb 1-1-port5: unable to enumerate USB device
I'm driving the Pi with a Lab supply set and confirmed to be 5V with plenty of umph so power should not be a factor.
Any other ideas? How can I test/verify that the cable is working correctly?
Many thanks
Marcel
Raspberry PiVE.Direct
Mike Dorsett avatar image
Mike Dorsett answered ·
With the cable plugged into the USB port, you should see the serial interface listed in the /dev folder.
I use some simple python code to communicate with a smart shunt and an MPPT unit:
import serial
from serial.tools import list_ports
from serial.tools.list_ports import comports
def Find_VED():
VED_port = ["null"]*4
com_ports_list = list(comports())
for i,port in enumerate(com_ports_list):
if port[1].startswith("VE Direct"):
VED_port[i] = port[0]
return(VED_port)
This will return a list of the available USB serial ports with VE direct devices attached.
tinkernut answered ·
Hi Mike,
Thanks for your answer - much apreicate it.
Unfortunately, I don't have any comports to list.... lsusb doesn't even show the adapter
root@raspberrypi2:/# lsusb
Bus 001 Device 009: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 008: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/dev only contains standard devices but no ttyUSB0
I'm trying to find out if the cable is defect or if there's something else going on.
Thanks
Marcel
Unfortunately, lsusb won't give you the information that you are looking for.
debian@beaglebone:/var/lib/cloud9$ lsusb
Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 005: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 004: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 003: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
OK, so I'm now using bones in stead of pi's (can't get pi's easily).
The above is taken from my system, that has 2 active VE direct cables.
Just initiate a terminal window, use python in the interactive mode, and try the commands listed above.
Mike Dorsett avatar image Mike Dorsett commented ·
debian@beaglebone:/var/lib/cloud9$ python3
Python 3.7.3 (default, Jun 29 2023, 18:03:57)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import serial
>>> print(com_ports_list[1])
/dev/ttyUSB2 - VE Direct cable - VE Direct cable
>>> for i in range(0,4):
... print(com_ports_list[i])
/dev/ttyUSB3 - MK2USB COM Interface - MK2USB COM Interface
/dev/ttyUSB1 - VE Direct cable - VE Direct cable
/dev/ttyUSB0 - USB2.0-Serial
Mike.
tinkernut avatar image tinkernut commented ·
Hi Mike,
In your case, lsusb shows 3 FTDI devices - but I don't see any when I run it here.
I can't query the USB cable because the OS (switched to an ubuntu PC by now - more troubleshooting capabilities) doesn't detect/recognize the cable.
lsusb should at least show the FTDI Device - python won't be able to talk to it otherwise.
marcel@ntp-ca1:~$ lsusb
Bus 002 Device 003: ID 0bda:0415 Realtek Semiconductor Corp. 2-Port USB 3.0 Hub
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 001 Device 003: ID 0bda:5415 Realtek Semiconductor Corp. 2-Port USB 2.0 Hub
Bus 001 Device 005: ID 1546:01a7 U-Blox AG [u-blox 7]
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. RTS5411 Hub
marcel@ntp-ca1:~$ python3
Python 3.11.4 (main, Jun 9 2023, 07:59:55) [GCC 12.3.0] on linux
>>> import serial
/dev/ttyACM0 - u-blox 7 - GPS/GNSS Receiver
The detected one is expected - GPS Receiver.
These are the errors in dmesg when the cable is plugged in:
[78028.121129] usb 1-3: new full-speed USB device number 11 using xhci_hcd
[78028.121317] usb 1-3: Device not responding to setup address.
[78028.329292] usb 1-3: Device not responding to setup address.
[78028.537126] usb 1-3: device not accepting address 11, error -71
[78028.537309] usb usb1-port3: unable to enumerate USB device
while unusual, I suspect the cable is broken. I've tried multiple different PCs - all with the same result. (mainly to rule out power issues - RPIs are prone to them)
Any other ideas?
Thanks
Marcel
Then it looks like your VE direct cable is defective. FTDI do have a utility for programming the data into the FTDI device, and setting up its function / responses. Not sure where to down load this from though.
I found this page: https://ftdichip.com/utilities/
Do you know the model of the chip used?
Mike Dorsett avatar image Mike Dorsett tinkernut commented ·
not without taking one of my leads apart - the open one is currently in service.
try:
FT_PROG 3.12.38.643 - EEPROM Programming Utility
but note the warning!!
Update: returned the cable for replacement.
