Kervin Keerd avatar image
Help needed with off grid system Quattro 48/10000 with Sonnenshein A602/1130 batteries
I have installed solar system with components: quattro 48/1000/140, 2x MPPT 250/70, CCGX, BMV712, batteries Sonnenschein A602/1130 48V. How I can adjust settings, that quattro shut off loads when SOC is below 60%? And turn on loads again when SOC is above 70%? And how is correct way to adjust settings, that MPPT won´t damage batteries?
offgrid
Hello @Kervin Keerd,
As mentioned in the warnings at the top of these following documents, it is required to work with a trained Victron technician for this level of programming. It is possible to do damage.
The manual for the Quattro controls is here:
https://docs.victronenergy.com/veconfigure.html
Specifically The inverter settings around SOC.
The manual for MPPT configuration is here:
https://www.victronenergy.com/live/victronconnect:mppt-solarchargers
Neither of those documents will be able to assure your system is correctly configured though.
You have many thousands of dollars worth of equipment there, it should last a VERY long time. Please make sure it is installed and configured correctly by using a professional service with the appropriate training and experience.
