sv-unsinn avatar image
sv-unsinn asked
Venus OS 3.10 Issue with missing Autostart Settings in Cerbo GX
I have an Fischer Panda Generator connected to the Cerbo using the interface box. I did the update to 3.10 and all info for Autostart settings and Motor data are missing. I searched all other settings but can not find it. I went back to 3.0 and all is ok again. Do i need to change something on the interfacebox ??
Venus OS
Hi @SV_UNSInn thank you for your report! we looked into this, and found the problem.
We're working on a fix; which will first be available as a beta version; and soon (one or two weeks I expect) as v3.11.
all the best, Matthijs
sv-unsinn answered ·
Thank you for your fast answer.
6 comments
Martin (Victron Energy) avatar image Martin (Victron Energy) ♦♦ commented ·
@SV_UNSInn Did updating to v3.11 resolve your issue?
sv-unsinn avatar image sv-unsinn Martin (Victron Energy) ♦♦ commented ·
Yes, it fixed the issue. Just one thing I can’t find was the settings fiebrige Generator Service Alarm/ notification. Again. Thank‘s taking care
Best
Stefan
Martin (Victron Energy) avatar image Martin (Victron Energy) ♦♦ sv-unsinn commented ·
Could you explain what you mean with "Just one thing I can’t find was the settings fiebrige Generator Service Alarm/ notification"? The Fisher Panda genset itself has never been able to push alarms.
The (separate) generator start/stop service can push alarms when:
  • There is no generator detected on AC input
  • The service interval has exceeded
  • The remote start functionality is disabled. Fischer Panda calls this Autostart.
These settings can be found in Fischer Panda -> Auto start/stop -> Settings.
Ah, ok. Than it was my misunderstanding. I thought that I would be able to set an alarm/notification when the service period ( hours) are exceeded.
All good as this is a very minor point :-)
Best
Stefan
You can, see GX manual here.
Oh, thanks for the hint. I will check it when we are back to the boat in March next year.
Best
xavier-64 avatar image
xavier-64 answered ·
Is it the same point has since I've updated to 3.10 I can start the Genset but I can't stop it anymore !
The relay physically don't change state. (I need to go to the setting to change it to manual to stop the genset)
Xavier.
Ivar Wagle avatar image Ivar Wagle commented ·
I have the exact same issue after upgrading to 3.10.
sydasssy avatar image
sydasssy answered ·
Hello, same issue, wnt back to V2.94 ich was the last stable one i had...
anyone solved the auto start/stop on any version when 2 gensets fischer panda installed?
Hi @SyDasssy, I'm afraid having multiple Fischer Panda gensets is not supported. We only support one of each type of generator: relay controlled and via comms, like Fischer Panda and DSE.
