colroo1 avatar image
colroo1 asked
Victron easysolar not showing accurate battery charge.
Hello. My easysolar shows 89% when the actual battery shows it is full. 246ah of 246ah.
Are there some settings i have missed out . I have tried with the easysolar managing the battery and the battery bms managing and displaying via canbus.
Any suggestions appreciated. Thanks
EasySolar All-in-One
Alexandra avatar image
Alexandra answered ·
@colroo1
Check in settings - system set up. It would seem the inverter is using its internal monitor rather than the can bms for the display.
You can change that there.
How have you programmed it otherwise?
colroo1 avatar image colroo1 commented ·
Hi. I have had it hooked up with both the canbus and the internal monitor. As to settings i just used victron conect app and used the recommended settings for the battery . Jakiper 48v 230ah that is 246ah.
klim8skeptic avatar image klim8skeptic ♦ colroo1 commented ·
@colroo1 you might want to check out Andy's videos of the Jacci battery.
Also check out the info regarding "Pace BMS" clones.
Alexandra avatar image Alexandra ♦ klim8skeptic ♦ commented ·
Maybe cmshare your settings?
Battery efficiency?
State of charge when bulk is finished?
Battery charge profile?
