ndb avatar image
ndb asked
BP-65 remote terminal connections
There is some confusion regarding how to connect the remote terminal on the BP-65 (and other BP models). There is no H or L written on the device as described in 3.1 (10) of the manual and which is common with Victron remote control terminals. The manual states terminal 2.1 as being the H terminal (battery plus for on) but schematic 3.3.1 and 3.3.4 shows 2.2 (furthest from the 3 pin block) as being the H terminal. So which is the correct connection for switching on using battery plus and if that is called the H terminal, can you switch on using battery minus on the other terminal (L)?
NOTE: On the smart versions, there is an H and L mark on the remote terminal. H is furthest from the 3 pin terminal block. Is the non-smart version of the electronics the same?
Battery Protect
