groanman avatar image
groanman asked
SOC shows much higher than actual state
BMV-700 with 2 12v batteries and a 100w solar charger.
After a very sunny day of sailing, my SOC says I'm at 97.8%. However, battery voltage is at 12.45V which indicates its rather around 80% charge.
Previously, I had the batteries falling below 12V with the SOC still registering in the 90's.
I have made sure the correct battery capacity was set in the settings and I'm confident I have no other battery draining that wouldn't be registered by the shunt.
Any idea what could be the issue?
SOC
groningen avatar image
groningen answered ·
@GroanMan
Do you have a Shunt installed in your system?
groanman answered ·
You mean the one that came with the BMV that measures current draw? Yes I do
kevgermany avatar image
kevgermany answered ·
Usual cause is incorrect settings in the BMV. Are you charging from solar? Are your batteries AGM or lithium ?
Please post a screen shot of the BMV battery settings
