rb20tez avatar image
rb20tez asked
Lynx Dustribution fuse - low amperage
Hi all, installing a Lynx distribution and i see that it only accepts maxi fuses.
I will be connecting the following-
2 x 12v 100/20 mppts
1 x 12v 100/30 mppt
1 x dcdc orion tr smart 30
The smallest maxi fuse i can find is 40amp.
To me that'd be too high for the above items, has anyone found smaller maxi fuses for these types of components?
Cheers
lynx distributor
kevgermany avatar image
kevgermany answered ·
As long as your cables are sized for 40A, this is fine.
seb71 avatar image
seb71 answered ·
A Lynx Distributor is too expensive (proportionally) for such a small system.
Use smaller busbars (you can even DiY) and fuse holders.
rb20tez avatar image rb20tez commented ·
I've actually got the lynx power in that I've added the extra bolts to so i can fuse it.
I did look at the cost comparison and it worked out close enough for me because i like how neat it'll all look too.
seb71 avatar image seb71 rb20tez commented ·
Yeah, the neat look and compact size is hard to replicate with separate components. But worst case, it should cost less than half the price.
