johnplyler avatar image
johnplyler Suspended asked
Electrical System Setup
I am setting up my electrical system for the first time.
I have LiFePo4 battery to charge and control.
I plan to use a Cerbo GX as the main controller along with the Wakespeed WS500, REC-Active regulator, Victron MPPT and Victron Multip-Plus.
My question: Do I need to load the battery parameters into each component, or just the Cerbo?
Thanks
cerbo gx
Sarah avatar image Sarah commented ·
Hi @johnplyler sounds like a decent system you are putting together. I am wondering what sort of BMS you are using and what your thoughts are on charging the house bank from the alternator. Kind regards Sarah.
2 Likes 2 ·
Alexandra avatar image
Alexandra answered ·
@johnplyler
You have to program all the components separately.
The Cerbo does become a coordinator in the system as well, but it is best if each part knows its job as an individual.
ejrossouw avatar image ejrossouw commented ·
It it vital e.g. were the cerbo to fail, the MPPT will revert to its settings and continue charging.
johnplyler answered ·
Thanks so much! You will not believe how many times I have asked this question - DragonFly, Current Direct, Off Shore Marine, Sprinter Forum, but you knew the answer! Thanks again!!!
